During a diagnosis in a Panda '03 1.2 8v with IAW 4AF with the idle speed irregular releasing throttle, I've found the parameter "adaptive idle opening" to 6500% and the "phonic wheel" value to KO. I've made a self adapting values reset (with the adaptation of phonic wheel also) and now the idle speed is ok, but this parameter is also at a similar value. The program was in the 1.0 release, if can be useful. Is this a normal value or not? While simulating a similar diagnosis, the value is writed as a percentage (so between 1 and 99).
Thanks for your response.
@Yani: on MES notes for the adaptive values reset, you have to add the 4AF to IAW systems that requires the phonic wheel adaptation with 3 "courses" to 4500 rpm.
[IAW 4AF] Adaptive idle opening 6000%
dallas140cv
electromida
Re: [IAW 4AF] Adaptive idle opening 6000%
Hi dallas 140, I got the same problem, my adaptive idle opening has the same value. have you found a solution to this problem?
