hi just like to know what the Adaptors connections are for i think the red adaptor is for the Airbag the green one is for the ABS and p/ Steering and the Yellow one is for low speed can well i think thats they for just need some one to let me know if that correct and also have a blue KL connection not sue that for please can some help me with that and i have also a black EL connection I think this is use for scan motor / gearbox have not use them yet just need some one to let if that was right one to use
i have been using the Launch x31 scan tool with the super 16 connection that does it all for me but was thinking the Muliiecuscan is better to use for Fiat / Alfa thanks
Re: Adaptors connections
RED adaptor is for AIRBAG system.
GREEN adaptor is for: ENGINE, ABS, power steering and XENON lights.
YELLOW adaptor is for LOW CAN system (new cars).
ok thanks i try it today on a Alfa GTV with air bag light on used the black EL connection with the red OBD11 connector with no joy do i have to do anything to black EL connection ?? to make it work like simply removing one resistor from the interface ?? i had a look inside and no resistor where it show just a Cap where the Resistor should be removed do i remove the resistor ?? thanks i got the Lauch x31 scan tool out and it worked ok the plug under the seat needed to be just be clean with CO cleaner and clear code and all was good but wish i could have done it with the Multiecscan maybe i need to but the Multiecuscan 1.3 MULTIPLEXED tool hope that one works ok does any one have one out there and can they let me know does it work ok thanks
If you want to connet to airbag system on Alfa Romeo GTV than you need only KKL interface and red adapter.
If your Alfa Romeo GTV is older and have 3 pin connector for airbag system than you need KKL interface and 3 pin connector.
