i have a stilo 1.6.
just got my cable through and will be downloading the software at the weekend and trying it out.
looking through everything i was just wondering, was does connecting to the pin 3 actually allow you to do with this software???
Thanks!
						pin 3?? what does it do?
Re: pin 3?? what does it do?
please read this subject:
"Board index ‹ Usage Q&A ‹ VAG KKL cable connections"
in this subject you will find all informations that you need!
or go direct to:
viewtopic.php?f=5&t=255
or go direct to:
				mihaitza83
if you haven't got an answer by now then alow me:
pin 1. abs
pin 2. unused for the moment
pin 3. airbag (srs)
pin 4 and 5 are for ground -
pin 6. Can High (ELM 327 v1.3)
pin 7. engine
pin 8, immobilizer
pin 9. electronic systems connected to dashboard cable
pin 10. bus + line
pin 11. Electric Steering (alarm, radiofrequenti receiver)
pin 12. electronic systems k lines connected to engine compartiment cable
pin 13. electronic systems k lines connected to rear cable
pin 14. Low Can (ELM 327 v1.3)
pin 15. L line
pin 16. battery power +
						pin 1. abs
pin 3. airbag (srs)
pin 7. engine
pin 8, immobilizer
pin 10. bus + line
pin 15. L line
