I own Grande Punto Starjet 2007, VIN ZFA19900001248570.
I'm trying to set up air sensor 7 175 3245 to my car. The problem is with activation via FiatEcuScan 3.5. I have enabled it and then tried to apply Proxy alignment. However, I don't see outside temperate results on my body screen.
Is it possible to activate it on my car, any answer will be appreciated
add air sensor to Grande Punto Starjet 2007
corbandalas
Re: add air sensor to Grande Punto Starjet 2007
Did you try with newer version of MultiEcuScan?
I know that this feature (outside temperate) did worked on FES 3.6 version, so if you have it try with FES 3.6 or higher MES version.
