Fiat Doblo 1.9 Multijet 2007 service reset
I have the registered version of the multiecuscan and a compatable elm327 version 1.3 interface, which works fine when looking at the engine. I would like to reset the service clock as i have done my own service. The software will not connect to the service mode on my car. Can any body advise me on why this is happening or maybe even advise me how to reset the clock in another way.
Thanks for your help.
John
John
Re: Fiat Doblo 1.9 Multijet 2007 service reset
hi, i would be very grateful of any advice you could give me. thank you again.
John
John
Hello John
Can you connect to the Body Comp. ; CAN setup; instrument Panel
produce?
What interface do you have? Ebay?
I guess here is the solution of your problem
viewtopic.php?f=5&t=1493
produce?
thanks for your reply Eddy, i bought this interface
http://www.ebay.co.uk/itm/CAR-DIAGNOSTI ... 338d6df6a9
it seemed to work fine in the engine mode. can carry out all the necessary stuff on there. but it does not work on any of the other modes. i just checked. I can not enter can set up in body mode. Can you advise me on what to do next and maybe if my interface is not acceptabe, could you please advise me of one that would be. The cheaper the better obviously, however Id like to buy one that does the job.
Thanks again.
John
Thanks again.
John
Hello John
In the UK there is a seller who specializes in interface for Multiecuscan. http://www.gendan.co.uk/
But this seller has changed its interface according to my information. And therefore are directly usable without modification.
Only in Germany is the
http://www.ebay.co.uk/itm/160996649487? ... EBIDX%3AIT
If you skillfully yourself. Do you find in the link in the last post more info
otherwise open your interface and send me two good pictures of the board.
I will then tell you what you need to change.
Thanks Eddy, that would be great. I will have a go at opening it up and I will send you the pictures. I will also have a look at the links for new ones you have sent me.
I'm away for a couple of days now so I don't have it with me. Will send you the pics as soon as I get back.
Thanks again.
John
Thanks again.
John
Hi Eddy, I have just had a look at the interface from Germany. Does this one definantly work? It looks almost identical to the one i already have.
Thanks again
John
Thanks again
John
Hello John
Yes definitely works John
As I have written!
The seller has modified it according to my information.
If you order it
Mr. Ulbricht send a greeting from me (Eddy) with.
As I have written!
If you order it
Hi, o ended up having a look on ebay again and found an interface that has been modified for multiecuscan. Cost me 18 pounds and works perfectly. If any body wants the link, please let me know. Thanks for all your help.
John
John
Nice that I could help you
