Injection timing
Injection timing
Hello. I have the following question. What does parameter Injection timing ? Whether it should be 0 degrees? I it varies from 0.5 to 2.8 degrees. Auto Bravo 07 1,4 Turbo 16V. Thanks!
Re: Injection timing
Easy, is equivalent to the ignition timing (spark advance) in Otto engines. Have to vary yes, but not much. I do not know the limits but if the engine works well, okay ...
Richardfamn
Injection timing
i have a 1994 triton diesel with a 4D56 engine, correct injection timing is 7 degrees atdc. i checked it with a pulse adapter and got 7-10 degrees btdc, what should the timing be or how much of an advanced reading do you get when using the pulse method, thanks.
