ELM 327 cable
ELM 327 cable
Hi there
I have a punto year 2002 1,2 16v with problem with elektro steering, i conneted my laptop with Multi ecu scan registred version, but it will not work only on engine ECU. Have then read for electric delphi i shall use ELM 327 connection. But which one to buy? anyone can help?
Regards Tommy
Regards Tommy
Re: ELM 327 cable
May be that is treated your problem here ???
In the motor control, you can connect ??
Re: ELM 327 cable
Hi Alfaeddy
Thanks for reply
When i started to use MES for 4 year`s ago i bought a cable called KKL 409 USB, with this i can only connect to engine ECU not for steering, and now i have problem with steering so i need to read error codes for this. I have the registred version MES. and after reading instruction it seemes that i need a cable called ELM 327 but which one?
Thanks for help.
Tommy K.
Thanks for reply
Thanks for help.
Tommy K.
Re: ELM 327 cable
Hello TommyK
Here a functioning BT ELM Interface
http://www.ebay.de/itm/151635712678?_tr ... EBIDX%3AIT
these dealers you can write if you have a USB ELM
would like to have
would like to have
Re: ELM 327 cable
Hi Alfaeddy
Thanks for help, Before you send me the post with link to a cable , i ordered one here in Denmark
http://mrperfect.dk/obdii-universal/16- ... odukt.html
I hope this will work, what do you think. Otherwise can i ask you for help?
Regards Tommy.
Regards Tommy.
Re: ELM 327 cable
Hello Tommy
But this is a very expensive interface 44 €
I hope that it works.
The dealers are indeed at
(new version 1.5a)
(new version 1.5a)
Re: ELM 327 cable
Hi Alfaeddy
It Didn´t work , so i have returned the cable, and ordered the one you adwise me. Hopefully it will work so i can read error for electric steering on my son´s punto.
Regards Tommy
Regards Tommy
Re: ELM 327 cable
Hello Tommy
Have you ever taken a test interface ??
What is displayed?
And this interface is probably one of the first that have been described here
viewtopic.php?f=5&t=1493
What is displayed?
Re: ELM 327 cable
Hi alfaeddy
Did you mean the " test interface function"?
yes, and when run it say´s ok, but it will not connect, only on engine ECU where it make a fault code.
So therefor i ordered the one you send me a link and i hope it will work.
The problem with steering i hope it´s only the relay´s, them i also already have ordered from Germany, can´t
Find them here in Denmark.
Regards Tommy
Regards Tommy
Re: ELM 327 cable
Hello Tommy
With testing I mean
Select MES / Settings / Interfaces / used Interface / Test
Only then you can see whether the interface used works
only then remove the possibly existing bridge resistance.
With testing I mean
