clock oil in te dashboard abarth
You can turn the engine information in the dashbord fiat stilo abarth mounted on a stilo jtd to see the pressure and oil temperature. Please answer if it is possible or not. Thank you.
Re: clock oil in te dashboard abarth
Maybe I did not understand it very well...
You have a Fiat Stilo Abarth dash and you would like to put it on Fiat Stilo jtd?
You would like to activate or deactivate some additional functions?
I do not think that is possible...
As far as I know most of Stilo Abarth models are with petrol engine.
Some electric parts on petrol cars, like dash, do not match with diesel models...
The JTD engine does not have oil temperature or pressure sensors. It only has an oil pressure switch. If you are able to fit, and wire, the additional sensors to the JTD engine, then it may work.Pitu1977 wrote:You can turn the engine information in the dashbord fiat stilo abarth mounted on a stilo jtd to see the pressure and oil temperature. Please answer if it is possible or not. Thank you.
The Stilo eLEARN workshop manual shows oil pressure and temperature guages for a JTD with the multi colour instrument panel.
Thanks for the answers. First I need you to activate the color screen dashboard clocks to complete the installation of the sensors.
