Hi everybody,
I am new here, I recently buy this program, for the injector programming of a fiat punto 1.3 jtd.
I got a elm interface 1.3+, and try to get the injector coded. all goes well, till i get to the point for saving the new data.
I get the message "interface not compatible"
Can somebody give me a glimps to what i do wrong?
In the list of the cars's compatible functions, i see the KL ELM to be compatible with the Marelli injection system,
so i can be sure it should work?
Marelli 6JF EOBD Diesel Injection (1.3) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMOBDKey
Marelli SELESPEED CFC208F (1) Automatic Gearbox |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMOBDKey
Bosch ABS 8 |INFO|DTC|DTC EX|PRM|ACT| KL 1ELM 1OBDKey 1 A1
Bosch ABS 8 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL 1ELM 1OBDKey 1 A1
TRW MY97 Airbag (2F-2L-I) |INFO|DTC|PRM| KL 3OBDKey 3 A2
TRW MY97 Airbag (2F-I) |INFO|DTC|PRM| KL 3OBDKey 3 A2
TRW MY99 Airbag (2F-2L-2T-I) |INFO|DTC|PRM|ACT| KL 3OBDKey 3 A2
TRW MY99 Airbag (2F-2T-I) |INFO|DTC|PRM|ACT| KL 3OBDKey 3 A2
Delphi Electric Steering |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
Service Interval Reset (Base) |INFO|ADJ| ELMOBDKey
Service Interval Reset (Comfort) |INFO|ADJ| ELMOBDKey
Instrument Panel Marelli (Base) |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
Instrument Panel Marelli (Comfort) |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
Body Computer Delphi/Marelli (188) |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
Body Computer Marelli (188FL) MY03 |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey
CAN Info |INFO| ELMOBDKey
CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELMOBDKey
Denso climate control (Dual zone) |INFO|DTC| ELMOBDKey
injector coding issue fiat punto Van
Re: injector coding issue fiat punto Van
Nobody have any idea?
For future people that have the same issue and allso get zero input on this forum, i found the problem.
For the injector coding you need to use a KL cable, not a ELM327.
For some reason it only works with a KL. Any simple cheap vagcom cable will do.
Dont forget to set the latency to minimum and the speeds to maximum in your cable device options.
cheers,
cheers,
That's right. Injector coding works only with KKL or KL interface.
ELM can not do the job...
Sorry I would helped you but I am not always online...
