hi everyone
 I have a fiat marea weekend 1.9JTD, 2001
I purchased a ob2 cable and downloaded your software but for some reason
Cannot connect to ecu. I have followed your instructions for setup.
My laptop hp nx9010 p4 2.6g using the vag-com has set up usb port com 3 and
The led on cable plug lights up: pin 7 on the 16 pin car diagnostic socket is
Populated so has pin 7 on the 16 pin plug, when I try to connect after selecting
The vehicle the software message connecting comes up for around 10 seconds
And message bottom left says disconnected. Any help would be gratefully received.
recomended here from fiat forum
						fiat marea jtd
				shop soiled
Re: fiat marea jtd
do you have tried to connect your pc/cable to another car?
							'03 Fiat Stilo MultiWagon 1.9 JTD Dynamic
Re: fiat marea jtd
did you install all the needed drivers?
				shop soiled
Re: fiat marea jtd
hi no i have not tried that, it could be the cable (new one) just need to find a fiat,topogatto wrote:do you have tried to connect your pc/cable to another car?
or something to simulate on. len
				shop soiled
Re: fiat marea jtd
only those drivers that were on the vag com disc. lenalfa156sarajevo wrote:did you install all the needed drivers?
Re: fiat marea jtd
first:
you should install on you laptop Microsoft .NET Framework version 2.0
link:
http://www.microsoft.com/downloads/deta ... laylang=en
second:
you should install FTDI drivers version 2.06.00
link:
third:
you should open http://www.multiecuscan.net/HowToUse.aspx and follow the instructions
P.S. don't forget to restart your computer after installation of different drivers!
olso please read topic: viewtopic.php?f=5&t=255
link:
second:
link:
third:
