I did the service and oil reset. everything looks fine.
The only thing that isn't resetted, is the service info in my navigation system at the menu: "car info", "maintenance info", service date in: --- km (not the 35.000 km where I resetted it to)
Is this normal? or can I still do this?
jubykoen wrote:Hello,
greetings
You need to connect to reset service interval in MES and set the distance to following oil change and set value what you want. I recomended if you have the diesel engine value 15.000 km. If you do everything correctly than you wil see in My car value 15.000 km.
