Incorrect Conditions - Replacement of Control Unit and Injectors
chrisken
Post by chrisken »
I'm trying to use the "Replacement of Control Unit and Injectors" function in multiecuscan after fitting and programming new injectors on my 2.4 jtdm and the software is saying "Failed to execute" "Incorrect conditions to run the test".
Any idea what the correct conditions should be?
Thanks.
gionag
Re: Incorrect Conditions - Replacement of Control Unit and Injectors
Post by gionag »
Same situation here...
i get "failed to execute" and nothing else
chrisken
Post by chrisken »
Mine says incorrect conditions with the engine on and failed to execute with the engine off. Either way it doesn't work. Tried everything I can think of. Wondering if it's a problem with the software? Everything else works fine with it.
gionag
Post by gionag »
i have licensed MES... version 4.3
tested both with ELM (clone) and KKL.
same errors...
i have orderer a genuine elm 2.2 chip and intend to swap that with the chinese clone and see if something is missing
chrisken
Post by chrisken »
Same here. Let me know how you get on with the genuine elm device. My only other thought was to transfer my MES licence onto a different laptop to try that - but it seems like a bit of a long shot. It just seems so odd that everything else on the software that I've tried is working perfectly except this function.
gionag
Post by gionag »
Got that....
i don't think the switch of the platform will fix anything... but if it's not cost you much, you can always test.
I am waiting packet from canada...
keep you posted !
