I have Jeep Renegade 1.4 MultiAir 2015. I have some problems with communication - I have warnings when I try to connect to Brake System Node (TRW ABS/ESP/EPB module) and Engine Control Node (engine controller). What could I do in this situation? I have not possibility to make the proxy alignement. When I changed some parameters in BCM, I could not overwrite configuration in this two modules and odometer is blinking
My hardware specification:
1. ELM327 v 1.4 - STN1100
2. ELM327 v 1.4 - STN1170
3. MultiEcuScan 4.3
Some logs:
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Engine Control Node (ECM/NCM) FAILED! - Timeout error
Writing to module: Radio Frequency Hub Node (RFHM) SUCCESS!
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Incorrect conditions error
Writing to module: Electric Steering Node (EPS/NGE) SUCCESS!
Writing to module: Brake System Node (ABS/BSM/NFR) FAILED! - Timeout error
FAILED TO EXECUTE
(Multiecuscan 4.3)
2018-12-15 18:01:08
Jeep Renegade 1.4 16V MultiAir
TRW ABS/ESP/EPB
ECU ISO code: 51 85 91 0D 49
ECU serial number: TA8231155900590
FIAT drawing number: 52029708
Hardware number: EPB17614B7C
Hardware version: 44
Software number: KJEA17IR_03
Software version: 6201
Homologation number:
Functioning time (EEPROM): 59482
Operating time: 59499
WARNING: Invalid ISO code for selected vehicle system!
Third log from ECM is attached in file. Please take a look on file.
The ECM and the BSN have wrong ISO codes. I could connect to modules and clear errors, but I could not change configuration.
I try also connect to modules when I choose 500X, 500L. Please help me, because I need to make some changes in my car.
