proxy failure Punto won't start anymore
markrs6
Post by markrs6 »
Today finally the CANtieCAR interface arrived and as we have two fiat's with flashing odo's (one with a blue me failure and one with a radio/nav replacement -alfa-). Happily followed the installation instructions and off we go to the punto. Yes reading and connection was fine for what I could tell. Did a diagnostic run and indeed the blue&me had an error as the indicator lights and rear fog light.... weird. The BM module had an memory error so I cleared it. Then off to the proxy, changed the iphone usb input and the rearfog light to left. But -and yes in all the excitement I did not read the manual properly- I kind of forgot to execute the proxy alignment.....I know it is kind of stupid and totally my bad in not reading up! Did another diagnostic run and all kind of errors came up (see below). And now as I just wanted to check the car will not start! It clicks a bit and the turnsignals flash.............. So please help I what to do next, before everything is broken; should I check the battery first to be sure and or disconnect it or do the proxy alignment now or reset to previous values and then do the proxyalign? Thanks!
REPORT1
Scan vehicle for available modules and check each module for errors...
Engine / ECM
Magneti Marelli IAW 5SF3 CF4/EOBD Injection (8V)
ISO Code: 0D 07 D6 04 43
Body / BCM (Body Control Module)
Body Computer Delphi (199)
ISO Code: 40 83 23 04 BF
Errors found:
B1007-18 - Left direction indicators
B1005-13 - Rear foglights
B1034-13 - Inside lighting (button panels)
ABS / ABS/BSM (Brake System Module)
Bosch ABS 8 ESP
ISO Code: EC 07 83 86 51
Electric Steering / EPS (Electric Steering Module)
Delphi Electric Steering
ISO Code: 31 83 8A 04 97
Airbag / NAB/ORC (Airbag/Occupant Restraint Module)
TRW Airbag MY05 (Ep - PROXI)
ISO Code: EA 07 10 04 DA
Instrument Panel Marelli
ISO Code: 32 83 20 04 AE
Dashboard / CTM (Convergence Telematic Module)
Convergence Marelli/Microsoft (Blue&Me)
ISO Code: B5 83 0B 85 9D
Errors found:
B1005-96 - Internal error
Climate control / HVAC (Heating Ventilation Air Conditioning)
Denso climate control
ISO Code: 34 83 0D 04 9D
VEHICLE SCAN REPORT
Scanning ...
Engine / ECM
Errors found:
Bosch ABS 8 ESP
2/12/2019 4:49:42 PM
vehicle diagnostics software for italian cars
2 www.multiecuscan.net
Errors found:
COMPLETED
REPORT2========================================================================
Engine / ECM
Errors found:
B1009-16 - Battery voltage
Bosch ABS 8 ESP
Errors found:
B0101-16 - Control unit power supply
Errors found:
B1902-77 - Left distribution motor
