Hi!
My old dashboard started to do mysterious things (car off random lights etc) so I changed it to new (used) one from same year car (Fiat Punto 2001 1.2 8v). Works great but I can't stop it from blinking. With proxi alignment procedure I should get rid of that but: "Dashboard Node (IPC/NQS) FAILED! - Data out of range error." I get this every time. Only difference is that new one is 9 months newer and has only half of the kilometres driven. Should I try to change the kilometres to same which I had in old dashboard to get rid of that data out of range error? Or does that mean something else?
Fiat Punto 2001 Proxy Alignment: Dashboard Node (IPC/NQS) FAILED! - Data out of range error
Re: Fiat Punto 2001 Proxy Alignment: Dashboard Node (IPC/NQS) FAILED! - Data out of range error
Hi!
I changed the kilometres to same as in the ecu but no go. Also tried another dashboard but it still won't work, got same error. I've done the proxi alignment to friends car years ago with success so my ELM327 1.4 cable should work normally. Would older multiecuscan work better? It was 2.4 or something like that when it worked.
Greetings from Finland
