CAN CONFIGURATION DATA:
6B 00 00 04 02 00 00 00 6B 00 00 04 02 00 00 00 02 00 00 04 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00
6B 00 00 04 02 00 00 00 09 00 00 04 02 00 00 00 6B 00 00 04 02 00 00 00 09 00 00 04 02 00 00 00 09 00 00 00 02 00 00 00
33 36 32 32 35 30 32 30 32 30 32 4F 55 54 50 55 54 2D 4A 49 54 20 13 06 11 6B 00 00 04 02 00 00 00 09 00 00 04 02 00 00 00 55 40 13 07 35 40 00 20 B0 10 00 2E 00 5A 00 88 06 0A 03 46 00 00 00 00 01 00 05 04 00 00 00 00 37 00 00 00 00 11 01 73 30 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Receiver Radio (NRR)
Airbag Node (NAB/ORC)
Convergence Telematic Node (CTM)
(Multiecuscan 4.4)
17/04/2019 17:50:07
Fiat Fiorino '07 1.3 Multijet
Receiver Radio (NRR): Ok
Airbag Node (NAB/ORC): EOL Failed
Convergence Telematic Node (CTM): EOL Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Airbag Node (NAB/ORC) FAILED! - Request out of range error
[102A] errors: Byte 67: 00->30
Writing to module: Convergence Telematic Node (CTM) SUCCESS!
FAILED TO EXECUTE
Airbag Node (NAB/ORC) FAILED! - Request out of range errorI can connect to the airbag module and read/change values without issue, but when it comes to Proxi I hit a brick wall.
It happens the same with another, identical, Airbag ECU unit I have for the vehicle.
Any advice to be given on this?
Thanks,
Sean.
