I did a neutral signal learn, the car forgot the learned position but the operation shows "status unknown" and then Turn off key immidiatly.
The signal is not learned, MES disconnects and sometimes will not reconnect until MAR off.
Now I have a DTC and Mil because of this.
Worked before, no DTC's, no sensor fault.
Wanted to relearn everything after battery replacement.
Tried two ELM327 devices, wifi and usb. Never had issues with connecting and CAN always worked.
W10, latest updates.
Edc17c69
Delphi does not know this ecu so I have no alternative.
Giulietta edc17c69 cf6 neutral signal learn does not work
mechanicalhodor
Re: Giulietta edc17c69 cf6 neutral signal learn does not work
Hi guys,
I have the same problem with a Fiat 500X - I ran this adaptation as the stop start system hasn’t been activating despite no errors. I now have an OBD fault and despite repeated attempts can’t correct - can you advise?
Try it with engine running, that helped me.
nelly19780
Did you manage to sort this issue out?
I have the same problem.
Do you have to have the engine running when running the relearn procedure?
The awnser is allready in the topic.
Try it with running engine.
I did not find any other way.
I think a lot of procedures are not working or described wrong. Was not satisfied for 50 euro's a year, I went to clone Delphi / Autocom.
nelly19780
Thanks.
Does the Autocom have this feature?
nelly19780
I have tried this with the engine working and it states it cannot be done with the engine running??
Neil
Neil
