I have a Lancia Thesis 2.0 TB and I always have a problem after using Multiecuscan. When I turn on the car after using Multiecuscan, it always have an unstable idle, even turning off by itself. And that happens a few days until it disappears and the idle is stable again. But if I connect Multiecuscan, the cycle repeats again.
What can be happening? When I connect to the engine ECU, it always appears the same permanent error, I've attached the last log to this post. Also, when I connect Multiecuscan, several indicators light on in the dashboard, specifically those related to the braking system (ABS, EPB, ESP) and I think this is not normal either.
Someone has the same problem? If you can help me, I'll apreciatte it very much
Thank you!
Unstable idle after using Multiecuscan on Lancia Thesis
Phaeton_82
