Hello, car Alfa Romeo Mito 2009r 1,4 tb 170HP
Multiecuscan 4,5
Activator MultiAir was repered (loose sleeve , car work for 3 cylinders and knock, no errors in ecu)
after repair I made adaptaion UniAir actuator dispersion correction and oil change, adaptation start rpm incrase to 1000rpm and after 20sek i gets info " DONE not OK"
check engine is flashing, engine works ok have power, dna work, multiair work only in full-lift, no errors
If I dont do this adaptation everything will be ok......
Please for help, sholud I buy new activator MA or how pass adaptation??
Mito MultiAir adaptation FAILED
Oliverautomotiveltd
Re: Mito MultiAir adaptation FAILED
Old topic but I don't suppose you got too the bottom of this fault? I have the exact same symptom and looking for an answer as someone must of got over this issue before?
Many thanks
Luke
Many thanks
Luke
I’m having exactly the same problem, can anyone help?
