SGW Jeep Renegade 2018 coding
CENTRORADIO
Post by CENTRORADIO »
I would need to activate the rear view camera input on a 2018 Jeep Renegade with SGW.
I use MES 4.6R1 MULTIPLEXED.
If I connect the SGW bypass supplied with the OBD interface and enter Central Electronics => CAN Setup / PROXI Alignment Procedure (BU) I find the SGW module "Removed" ... I stopped here for fear of making some mistakes.
If I activate the rear camera input and then perform the proxy alignment, is the SGW module excluded?
And then when I plug it back what happens?
Re: SGW Jeep Renegade 2018 coding
everything is fine. don't worry
RoyalHawk
Post by RoyalHawk »
CENTRORADIO wrote: 04 Mar 2021, 17:39 I would need to activate the rear view camera input on a 2018 Jeep Renegade with SGW.
The only issue, as reported by another user, is that when you reinstall the SGW it will not be seen in the list of nodes. This is due to the fact the alignment is done without the SGW
Cervelo
Post by Cervelo »
hi, did you manage to do proxy alignment without SGW/bypass ? Is everything ok as colleagues suggest? My km counter is blinking, I also plan to make a proxy in Jeep Renegade BU / 2019.
Cervelo wrote: 16 Mar 2023, 18:50 hi, did you manage to do proxy alignment without SGW/bypass ? Is everything ok as colleagues suggest? My km counter is blinking, I also plan to make a proxy in Jeep Renegade BU / 2019.
if car has SGW module you can't do proxi alignment without bypass.
Cervelo
Post by Cervelo »
Yes I my Jeep has a SGW and I bought a bypass. Now I'm looking for all key info. Did you do proxy ?
