ho acquistato licenza multiecuscan 4.7 r3 , dopo la scansione su ducato 290 140 cv 2300 del 2020 che non supporta controllo motore codice iso 00 01 50 6a 16 e abs codice iso 00 06 50 65 16 il body computer si.
come posso fare?
compatibilità multiecusca 4.7r3 con ducato 290 2300 del 2020
multiecustellio
Re: compatibilità multiecusca 4.7r3 con ducato 290 2300 del 2020
I have a similar Ducato 290 2.3 Multijet (140hp 9-speed automatic) from 2020
Using a modified ELM327 without a yellow adapter I can see the following units:
Engine / ECM
UNKNOWN/UNSUPPORTED
ISO Code: 00 01 60 70 17
Gearbox / TCM/NCA/NCR (Automatic Transmission)
ZF 9HP48 Automatic Gearbox
ISO Code: 52 85 04 0D 3D
Body Computer Marelli (290)
ISO Code: BF 83 8F 0D B3
ABS / ABS/BSM (Brake System Module)
UNKNOWN/UNSUPPORTED
ISO Code: 00 06 50 65 16
The Engine ISO code is different but the ABS ISO code is the same.
With the yellow adapter I can see the Airbag, Dashboard and some other systems.
Engine / ECM
UNKNOWN/UNSUPPORTED
UNKNOWN/UNSUPPORTED
