Can anyone with "Bosch EDC16C39 CF4" confirm that the injector codes reported by Multiecuscan are correct?
I implemented injector coding in the next release and need to know that those codes are correct.
EDC16 Injector Codes Question
Re: EDC16 Injector Codes Question
A want to know, your program can change injector codes on ecu edc15 c5 and c7? or if not do you think about this?
Thank you for your answare.
Jani
Jani
The next version can change the injector codes on EDC15C7. I think it is not possible to code injectors on earlier versions of EDC15.deco wrote:Hi
Jani
I am very hapy, if you can do it, I have a problem with edc15 c5 - alfa 166 2.4 jtd 100 kw, changed the injectors after i dont have enought power. i think, i must calibrate it.
jani
jani
edc15c5 not have the coding injectors
The injector in alfa 166 2.4 JTD 100kw cf2 edc 15c5 and
in alfa 166 2.4 jtd 103 kw cf3 edc 15c7 in electrical side is same,
Injectors in cf2 engine edc15c5 have code
if edc 15c5 cant change this code, then why have this injectors code?
If i change injectors in this car, what i need to do?
Are injector codes supported only for EDC16C39 or also for EDC16C8 (first 16V multi-jet)? Do you need ELM cable to read injector codes or is it doable on KKL cable?
Injector coding will be supported for EDC15C7, EDC16C8, EDC16C39, Marelli 6JF/6F3.
quando uscirà la nuova versione?
