Engine Type on Proxi Alignment - HELP!
rroope
Post by rroope »
I've been trying to change some settings on a Chrysler (UK) Ypsilon 1.2 Black&Red to cure a lighting fault, but noticed the engine type was wrong (this is on MES Moble App on iPhone).
I'm sure the engine type was listed as a 1.3 MultiJet, so I changed it to 1.2 8v. It's now coming up with ABS unavailable and CNG Fuel needed! If I change it back to 1.3 MultiJet, ABS unavailable is still coming up. Also, I've lost power steering.
CAN CONFIGURATION DATA:
6F 00 00 04 02 00 00 00 6F 00 00 04 02 00 00 00 4B 00 00 04 00 00 00 00 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 00 00 04 02 00 00 00 09 00 00 04 02 00 00 00 6F 00 00 04 02 00 00 00 09 00 00 04 02 00 00 00 09 00 00 04 02 00 00 00
33 32 34 30 32 30 30 34 32 31 32 4F 55 54 50 55 54 2D 4A 49 54 20 12 02 07 6F 00 00 04 02 00 00 00 09 00 00 04 02 00 00 00 93 C0 62 06 E5 00 00 21 A9 50 00 0E 00 07 00 94 06 0D 01 3C 01 00 01 01 35 50 0A 7C 00 00 00 00 15 00 00 00 00 11 15 30 01 20 00 00 00 00 00 03 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Receiver Radio (NRR)
Airbag Node (NAB/ORC)
Convergence Telematic Node (CTM)
(Multiecuscan 4.6R1)
26/04/2023 17:31:01
Chrysler Ypsilon 1.2 8V
Can anyone help resolve this issue please? Being that it was initially done on FESMobile, I VERY STUPIDLY didn't take a Backup!
Rich
chrener
Re: Engine Type on Proxi Alignment - HELP!
Post by chrener »
You have backup!
Check FESlog after first connection, there is original car configuration...
Erase all bugs and do steering angle calibration in EPS and ABS unit...
rroope
Post by rroope »
How do I access backups on the iPhone app? As that is now this was all done.
try setting it to type 4 - this should be 1.2 69HP engine
rroope
Post by rroope »
@shpuncik - thanks for that! The owner has gone away for the weekend so I will try after that.
