Proxy alignment failed due to Body Computer node
Hi, I hope I can get this all sorted as it's driving me mad. I have a 2015 Abarth 500 series 3 with tft dash from factory.  I have the flashing odometer and no blue and me, so I have extracted the blue & me module from it's hidey hole and sent it away to get repaired.  I have received my unit back all sorted and reinstalled it hoping that the flashing odometer will stop once I had done the proxy alignment, however it now just keeps failing to execute due to Body Computer node Failed Request out of range error. I also have the airbag warning light on and the engine management light too, and recently the tpms has joined the party by flashing up with 'ko' next to each wheel on the dash, whatever that's about.  I have version 5.2 of mes, am using the yellow connector lead. Car is driving fine but I don't know what is wrong.  Is the Body Computer also at fault or should I have installed the blue and me with the battery disconnected I just don't know. Help!!! Please..
