I have some VAG COM 704.1 and  VAG COM 805.0 (and 805.1) cables.
I can't understand how to solder pins 1,3,7,9 together to make the modified cable
work with Multiecuscan.
http://www.multiecuscan.net/HowToUse.aspx
http://www.multiecuscan.net/images/Photo003s.jpg
Is there any possibility to work with above cables? Or need older versions?
Can any one post a close-up picture and more details?
Note: Some of above cables, have lost the VAG COM activation, but still work as WIndows devices.
It still finds the interface in Windows. Is it safe to use them to check Fiat, Lancia, Alfa Romeo cars?
Or I should get NEW working cables? I really don't want to throw those cables. At least use this alternative
software, to make them work.
Thank you !!!
						VAG COM 704.1 or 805.x works with Multiecuscan?
Re: VAG COM 704.1 or 805.x works with Multiecuscan?
You can't use that interface with multiecuscan
You need an older version 409
So I will buy one. But I didn't undestand much about solvering those pins.mattydr67 wrote:You can't use that interface with multiecuscan
Is there a close-up photo?
What pin is to be connected with what? I am comfused !!
Buy a vagcom 409 interface and i will show you how you can do the pins soldering.
You how you contact me because we spoke in another forum. Don't you remember.
